just the front shocks? not ok to keep the front off mine on for a while,(cars not moving really)And you will need to replace the front shocks from a 6 cylinder car aswell
i have the clocks from another car,is that a problem? he had already sold the clocks..hmmm so onnly the cat section is different?Best bet is to get the engine and box together, make sure you get both ecus (one engine, one autobox) the EWS box and a key chip.
Grab the clocks whilst you are in there too, and at least the cat section of the exhaust, you may be able to pick up a fancy back box to finish it off.
slightly weaker? so what are the pro's and cons of keeping the 318is one? is it worth getting 328 diff then? thanks mateYou'll have a small case, high ratio diff.
It'll be slightly weaker, but give you faster acceleration.
