1 - 9 of 9 Posts
Im following the Bentley guide on resetting my Auto-up window feature for my coupe but its not working.
It says to:
Fully lower window
Fully raise window and hold button doen for at least 5 seconds to set the module.
Not getting any joy. Any ideas??
This is probably what you're doing but just in case:
1. Close door and turn ignition on.
2.Fully open front window.
3. Fully close front window. Hold window button in up position for at least 5 seconds after window is closed.
4. Repeat for remaining window.
If holding in the up position does not work then try holding down. If it works then you will here a click:thumbsup
Gildersol - yeah that is exactly what Im doing.
A20 RYM - will give it a shot. Ta.
No luck :( tried holding up down etc but nothing. Im sure when I got the car and before I disconnected the battery to change the steering wheel it worked, but not 100% sure. The car is a december '94 build - will it have the function as standard?
Discussion Starter · #7 ·
Yup - spot on
Discussion Starter · #9 ·
Yeah thats what I read too. Im sure it was working a few weeks ago....
1 - 9 of 9 Posts
