I have a 316 compact and lately the ABS light has been coming on randomly. If I turn it off and start again the light goes off but might come back on later. There isn't and pattern to it coming on but it seems to be coming on most times I drive my car. Also I have noticed that when braking gently it feels as if the ABS is coming on but only some time. Any idea?
The first port of call should be getting the fault codes read for the cars ABS ECU, any Main dealer(more expensive), BMW Independent specialist or good independent garage should be able to do this for you, get a copy of the codes and then post them up here and we will help out where we can with what you need to do next.
