1 - 10 of 10 Posts
hi every one was just asking bout some advise i have a 1.6 compact ad not very powerfull and have been offered a 1.8 is engine box and loom for 200 quid the engine has covered 75k and its genuine its my m8s car but what is involved in the change and is it worth it ?
Easy, does your ignition barrel look like this one?
If it does then your key has an EWS chip in it. You will also need the EWS module and engine ECU:thumbsup
The engine and box will fit straight in without issues. Would be a good time to replace and upgrade the engine mounts. If you do not get the parts that I mention then you need to walk away as it will not start if a single component is missing.
The chip from the key is easily removable so long as you take care:thumbsup
I'm not sure of the differences between your compact prop and the 318is as the compact uses an E30 rear set up:frown
1 - 10 of 10 Posts
