The passenger side works fine - but the drivers side makes a clicking sound when pressing the joystick up and down, and nothing sideways.
Any ideas?
It may be the result of the motor being seized?
Have you tried manually pushing the mirror to another position and then seeing if it will move when the switch is pressed.
I suppose there's also a good chance that the switch may not be making proper contact when switching from passenger to driver side:confused
Does everything else seem to be working okay?
The motor may have gone if there's no sideways movement, and up and down clicking may be teeth/gear damage
Thanks guys
Yeah I have tried manually adjusting and then using the switch - and have also replaced the switch too.
Sounds like its the motor - back ti the scrappy once more :D
