hya my pasenger auto close function on my car is playing up when i close the door it doest move up to seal. and theres a gap between the rear of the window and the rubber, but now and then the window will gudder like its trying to move up then goes back down again. :confused
might be the regulator as they tend to go/play up....i'll see if I can get some more info...
EDIT: More info as promised....take a look at these two articles, they go into replacement but you might wanna take a look and check it inside or just go for all out replacement your call....hth
http:// forums. bimmer forums. com/forum/showthread.php?t=380215 (had to space it out as it kept replacing it with ***'s!)
http://www.dvatp.com/bmw/diy/power_window/
The window tilt can be adjusted, it's shown here http://www.dvatp.com/media/image/e36_window_regulator_pivot_adjustment_marked_large.jpg
Do you have any problems with your interior lights? do they stay on if you select "on with door opening" when the door is closed?
well i did notice that when i open the door i cant get the int lights to come on, will this have anything to doo, i hear that there is a reseting procedure u can doo aswell. as i did change the glass and not worked rite since, cheers
The interior lights and drop down window function are linked:thumbsup
Do you have a copy of the bentley manual as the reinitialisation procedure is stated in there:thumbsup
Hold down the window switch button so window goes down and keep it held down for 20 seconds.
Window should now be sorted.
As for your interior lights the switch is on the drivers striker plate built in
