Hi there. Having read through several posts on here it looks like my recently bought 316i is in need of a new t/stat (running cold all the time).
Can anyone advise on bleed screws? I've found the one on the expansion tank/top of rad - are there any others? Just being cautious cos my last car (non-BMW) was a b**tard to bleed!
Thanks in advance,
Paul
Your e36 will only have 1 on the radiator
The 6 laws of bleeding...:silly
:hihi
