You need to establish whether you have fuel or spark at the plugs, pull a spark plug and put it in the coil and crank the engine over with the plug about 6mm away from a good earth point, it should spark. If yes then check for fuel from the fuel filter pipe by removing it and when cranked over. If yes then check for injector pulse with a test light or noid light.
