This is not a repeat of my post in the auto electrical forum about trying to get the system working, now that's solved (fingers crossed) I'd like to know if it's working properly so I need to check a few things.
OK, can anyone tell me if their system does the same as mine, or indeed anything different. It's the alarm with the single button 'corner cut off' fob.
When I press the button to unlock it I get:
flash with beep, second or so pause, then the doors unlock and the drivers side window seems to drop a few mm.
The pause here seems odd to me, is that the norm?
Then when I go to lock it again I get:
2x flashes with beeps and then it locks.
Exactly the same as mine - although mine is a 3G Mk2, and obviously the windows don't drop down a smidge as it's a saloon. :D
The short pause always used to confuse me at first, but I'm kind of used to it now.
Ah fantastic! At least I know that's normal now. Cheers.
