hey guys, i'm looking to get my interior re done, and i'm just wondering what seats would fit the cab, would the coupe ones fit? i know the salsoon ones wont, not sure about the coupe/compact
cheers
Where is the seat belt mounting point for your cabriolet? Is it just below the Rear door card in front of the rear seat? If so that's the same as the coupe:thumbsup
Saloon mounting point is incorporated into the seat itself:thumbsup
The top fixing point on the coupe is on the door pillar just above the seat.
I thought the cabriolet top fixing point was incorporated into the top of the seat:confused
ahhh yeah, the belts come out of the trim as such, they're about window level
Yeah I thought so, can't see from the picture that I posted.
Having said that you can use any E36 seat so long as it's in the use with your seat belt. The four door can't be used because it won't have the function for allowing passengers into the rear:thumbsup
Compact should also be okay
