Hi!
Recently swapped a 1994 M50 2.0 Vanos. Its from a Japanese spec car (JA75725...chassis code) and I was looking for the correct Lambda probe for this model.
On realoem.com and bmwfans.info, there is a Temperature probe alongwith a Lamda probe under 'NATIONAL VERSION JAPAN'. I am confused....do i need to install both?:confused
And what would be the NTK cross reference number for a 1738282 Siemens Lambda?
TIA
TheEnd,
I got the instrument cluster from the same car and it says 'JPN' on the speedo too.
But, if only a regular Titania 4-wire can suffice, that would be great:thumbsup
Can a NTK-25013 be used?
Have gone through different cross reference sites....the easily available and less dearer ones are the Titania sensors for the 323i and 328i. Hopefully, they will work.
Thanks!
