1 - 20 of 23 Posts
does anyone know how to fit a power boost valve im getting confused here how to fit it?
plus i didnt get any instalation instructions either
cheers kirk:rofl
arh but a problem there i have to fuel lines what if i get it wrong and wont i need to make a t piece for both regulators if you look on m42 engine its well head battering
and what about the vacuum line what do i do with that share the original with fse??
the old regi at the front were i disconnect the vacume line from,
Discussion Starter #11
excelent cheers ronnie well try it once i tried the starter.
Discussion Starter #12
fse pipe into feed line pipe on fuel rail then what about return pipe what do i do with that..
Discussion Starter #14
yeh thats the drawing it dont get aint you suppost to connect the feed line into the pvb then out of it onto the feed rail... that just doesnt make any sence at all.
Discussion Starter #16 (Edited)
power boost valve. i dont see were i can return it to the return tank its suppost to pressure into the fuel feed aint it..
Discussion Starter #17
ive put the pics up ronnie could you help any futher??
please................
There should be a adaptor I think to bypass the old fuel pressure regulator, it describes it in the link above.
Discussion Starter #19
it comes with a adaptor but doesnt fit..
1 - 20 of 23 Posts
