i have an 1994 E36 shape M43 engine 318i with air con.
today i went on longest trip so far about 30 miles (only got the car thursday). on the way home, pulling out from junctions and creeping in traffic the car would judder very badly when slipping the clutch. only happened when the engine had been run for 30 min mostly on the motorway so engine was fully warmed through.
its fine when its cold. the clutch isnt slipping at high revs. pulling away in 2nd judders less. pulling away with revs at 3k seems to be ok. just judders low revs pulling away. reverse also does it.
have noticed on here the problems with clutches on the E36.
what im worried about is getting a replacement clutch, and when it gets hot it starts juddering again.
can anyone recommend a clutch they have used without problems?
is the problem only with the bmw manufactured clutches and none of the after market kits such as sachs?
just that i dont want to spend a lot of money to not cure the problem.
roughly how many hours labour for a garage to swap the clutch, ill probably be supplying the clutch kit.
