Hi all new to the forums,
Ive search'd the forums about this but cannot find it..
i brought the car 2 days ago, took for a test drive and felt fine all but the rear drivers bearing that wasnt a problem as i could do this..
so anyway after the purchase i opend it up alittle as you do.
to find when i go over any slight bump the rear shakes to eaither side,,
anyway with the rear bearing i changed it yesterday,,
all gone fine with that but upon removing the hub to do this there's
the main bar from the hub that connects with 3 18mm nuts under the rear passengers seat.. the mount rubber in there is really pooped...
so the help i need is the correct term for that part, so that i can search on ebay or goto the bm shop
i'm sure its the bush but what bush is it called lol..
sorry nooby to bm's
give me a punto and i can name that but im stuck with this part name lol
so thats the help im needing since both have to be changed.. rubber mounts are kinda damaged real bad. so i prosume its this thats making it sway on the back end upon hitting a bump/pot hole...
Thanks and ill look forward to your replies..
sorry nooby to bm's
