checked the fues box under bonet is there one onside the car as well i was looking but could not see oneHave you checked the fuses yet?
Were ALL the fuses OK then?
Also did you connect the terminals the wrong way?
yer it is in the boot of the car where about would the link be also how do you check it and re active it new to this type of car alway had 69 model car beforIs your battery located in the trunk or in the engine bay? You will definitely have a fuseable link if it is in the trunk like some earlier 318is models.
