1 - 8 of 8 Posts
Hi once again, just had my mot and have had an advisory on my offside front (rear bush) suspension arm rubber being detiriorated but not resulting in excessive movement.
The side of the car on further inspection is about 10-15mm lower than the nearside heres a pic of what i'm thinking it is, if it's not would someone be able to supply a pic of what i need, i'm new to cars (own a few m/c's)
Cheers people!
Driver side arm connects to the wheel hub. The bush they are referring to is the troublesome one (go for a past time) that fits to the end of this and bolts to the underside of the car:thumbsup
You are an absolute legend, thanks so much!! :thumbsup I'll get on on order, might even do them both at the same time. Thanks again!!!
Discussion Starter · #7 ·
Lovely job, just spotted a set on ebay for about 45 delivered,
Thanks once again! :thumbsup
BMW e36s always sit lower on the Offside, it was designed to :hihi, so that when the driver was sat in the car it was level, but Germans drive on the otherside :frown
1 - 8 of 8 Posts
