1 - 20 of 25 Posts
hi there guys am new to the forum. just got myself my second e36, 325 tds and was wondering if anyone knew how to fit a dump valve?
seems to be pretty negative feed back for putting one on so will maybe just leave it, thanks for the feed back.
dont think dump valve make much of a noise on a Diesel do they? i wouldnt bother to be honest!!!!
Will make more noise on a derv! That's all you'll get though, there's no other benefits. If you do get one you'll hve to make sure it's up to the boost the car is producing. Tried one on my old 306 running 22psi boost and it was the equivelent of a huuuuge boost leak!
Diesel dump valve is impossible unless its a Derv Doctor one which is electric.
On a petrol turbo. The turbo boosts and when you close the throttle or lift off that excess bost creates a vaccum and opens the dump valve.
On a diesel the boost is re-used IE not wasted. So making a hole will, as said above, give you a major boost leak. They dont use butterfly throttles either so there is no vaccum to open it hence the reason your brake master cyl uses a seperate vaccuum pump on a diesel.
So in conclusion dont fit it, it will just release much needed boost.
as said above a diesel is on a low pressure system and it recirculates any un-needed boost back to the inlet and fittting a atmos dv will cause problems with the maf and o2 sensors aswel
Reactions: 31chael
I've heard somewhere before that dump valves shouldn't be fitted to diesels either?
Anyway you won't gain any benefits from it unless you have a bigger turbo/running higher boost etc. All you'll get is the sound, if thats what you want..
:thumbsup
hows it going sham? long time no see... got my turbo painted matt grey now.. :D
More than possible with a twin piston valve that can handle bigger boost than petrols. As said is controlled by a microswitch on throttle that can be bought for pennies (The derv doctor..not that great imo, wanted to charge me over £200 for something that took me 15 minutes to do myself..). So when you close the throttle it activates the valve. Bit pointless though as you say, especially on a classy Bimmer!
Yeah many of the 'felt spec' cars round my way are alldervs fitted with straight through exhausts which give a pooooooow noise when you shift basically the same as a dump valve.
Reactions: 31chael
my little input on this is if your after doing it mate try it. i used to have a derv doctor one on my 306td (which i didnt fit) and it was decent tbh. didnt change much on the running side of things just made a nice tishhhhh noise lol. ive heard some bad diesel kits too thou. alot of them chatter rather than a straight nice noise
Discussion Starter #18
yeah thats what am worried about mate. think am not going to do it now, disco stu's comment
changed my mind lol
i suppose if you where bringing some big bhp on a petrol one it would be a different matter. im a huge fan of dump valves dont know why.
it would be unique like
1 - 20 of 25 Posts
