Hi, wanted to ask a quick question about my central locking
it has always worked fine and never given a moments problem in the 2 years i have owned the car, but during the cold weather this winter it has just stopped working, i have checked the 3 fuses in the fuse box that deal with the locking and they are fine, i get no sound from the solenoid in either front door or the boot which i find odd as i have had older BMWs with 1 door not locking or the boot and have managed to fix it fine, but as they all stopped working at the same time and it is not an obvious fuse im a bit lost as to where to go next
i do not have a fob to lock the car with i just use the key
any ideas or points in the right direction will be gratefully received
chez
I take it you've tried each lock? Both doors and boot.
Does the CL work from inside? IE push the pin down.
Any other elecs not work? Windows, Sunroof etc etc
as billywhizz said try the boot wiring 1st,could also be the comfort relay playing up,i had similer problems but my e36 is a later model with the zke module that controls the windows and a few other things.there are posts on here about the comfort relay.hope you get the problem sorted soon.
mike
