my central locking fuse keeps blowing, it has a 25 amp fuse in it and replace it with another 25 amp fuse, is this the correct fuse or so u think its maybe a bad earth?
If this is fuse 7 it should only be a 5 amp. 25 amp is dangerous as it will allow too much current through the wiring. Better that you remove it and have no CL than your car catch on fire!
Also check under the carpet in the front passenger footwell.... Water is known to corrode bits under the carpet and cause these problems aswell as the bootlid :thumbsup
