Hello,
Is there a known way to read codes on a MS40 OBD I 1993 320i E36 car.
I bought Carsoft 8.4 300 euros and carsoft 6.5 65 euros. Both give me the same behavior:
it starts doing the diagnostic procedure. I get the red diodes tx rx blinking.
When the progress bar reaches the end, the progress bar falls back to 30% and goes up very fast then falls back to 30% and goes up very fast forever. tx rx blinking stops at this stage. I don't have any message from Carsoft. It just loops forever.
I was told to disconnect the ABS module, which I did. It did not change a thing.
The strange thing is that I don't have to put ignition 2 to get the voltage at the diagnostic plug.
Also all 3 diodes
K line 20
K line 17
L line 15
are all green, even when key is on ignition 0.
Point is: putting ignition 2 does not change described behavior.
Called Carsoft technical service and they haven't found a solution yet.
Thanks for any tips!
