hi i recently purchased this bmw i have one problem though the nearside headlight nearside full beam and nearside rear light are not working all other light work fine checked fuses ok check earths ok bulbs ok is this a major job or a possible self fix
cheers
mick
Try and get a multimeter and see if you get any readings from the bulb connectors...
Also check your boot wiring for wire damage as they tend to break over time and may lead to a short circuit.
And using a test light check for power at the fuses for the N/S, also try swapping the fuse anyway in case it has a hair line crack(had it before)
