My 316i (1993) has been humming/droning from the rear over the last 6 months and is slowly getting louder. It seems to do it from about 40mph and not at very slow speed. Notice it more so if cruising at around 50mph, slightly louder if going up hill. I think the nosie is fairly central.
Reading through this great site, I managed today to drain the rear diff oil. Oil looks OK and was probably about 1 litre which I believe is the correct amount (1.1 litres).
What is the best oil to fill it with? I see 75/90 mentioned quite a bit but would be useful if someone could recommend a brand....I have some Castrol Hypo E90, is that the same?
If the new oil doesn't cure the noise, are the rear wheel bearings the next most likley?
Many thanks
P.S. BMW 316i 1993, 117,000 miles, diff oil never changed to my knowledge
Many thanks
