Hi everyone, this may be relevant here, when I bought my 740 the interior light on the drivers side C pillar wasn't working, on inspection I could see the bulb loose in the case. I removed the c pillar to find that the metal contact in which the bulb is supposed to sit had was also loose (due to heat the plastic had gone brittle and broken which secures it).
I managed to secure the contact and then the bulb carefully and lo and behold the interior light began working again but wouldn't go off!
The problem was that the two earth wires in the C-pillar light were touching each other, I insulated these two connections and everything works fine again.
Hope this is of some help.
Please note though when removing the C pillar lights to inspect they clip in place, the top edge must be loosened first and then they fold down and can be lifted up and out.
