1 - 14 of 14 Posts
Hi guys
Be debating to lower the front of the 325 but unsure what to look for!
I dont wont to lose the smoothness of the ride to much as the b6 dampers steve put on are great but I would like to go a little lower on the front just to give it abit more stance.
Does any one any good and not to pricey makes of coilovers or springs that I could use?
Any and all info would be great.
Yer I will have a butchers to nite must double chech with steve to see if it was b6 dampers all round.
Cheers for the info
there's some coilovers by hot tuning or something on ebay. i know alot of people that use these and are amazing value!!!! £150ish !
i think you can adjust dampening aswell so you can have softer than standard or whatever you want
Ok cheers fella I will take a look once I am home cheers
BFuk Legend
Go for the Eibach pro springs on those Bilstien shock. The hottuning coilovers were the ones I had fitted before and were too harsh...:frown
You wont get a massive drop from the springs but you will keep the good quality ride....:thumbsup
I think the pro springs it is then depending on the drop.
Dont wont mad low just abit lower than it is now
Discussion Starter #11
Had a look and i think the 40 mm ones should be more than enough cheers for the advise guys :thumbsup
Discussion Starter #12
what about apex lowering springs anyone used theres before ??
Just to ellaborate Sutton as I was on my phone when I replied earlier, I wrote this on another thread. Not sure how it'll translate to an E36 or Bilstein shocks but you'll get the idea.
1 - 14 of 14 Posts
