Hi I have a 525 SE Auto 1990 low milage. Can any one throw light in the type of Throttle position sensor that i have on my car and how to set it up from scratch .It has a round connector (unlike most pictures in manules - oblong showing three spade terminals) with a number of pins which look as though they are laid out in pairs it is about one and a half inches in dia. and when pushed in has a secureing clip that is pressed over to insure that it cannot fall out. My car does not have a cold start valve an oxygeon sensor in the exhaust or an extra screw on the throttle body appart from the throttle lever stopscrew. it has the large round plug on the nearside that accepts an electronic readout tool which i believe is of 20 pins however looking at mine it only has about eight or nine of these holes holding a femail socket . All this considered can a recognition be made as to what series of Motronic it is . My local BMW garage ( not dealer) says very little info would be available from this plug and the cost of having a diagnoses done is not worth while. Problem jumpy tickove ..I have changed the blue temp. sender with a slight inprovement shown, no holes in any of the rubber breather pipes, tappets ok plugs ok, Air flow sensor tests ok ( note no aditional mixture screw for tickover here)
