Hello my handbrake needs ajusting on my car it works but its high up. So it will need ajusting soon. Wats the easyest way to ajust it?
Bmw se 520i 24v straight 6 1992 model.
thanks pete
wrong section to post in really..
You should ideally remove the drums and check the condition of the shoes, if theyre ok then you should adjust the "self adjusters" (note the cliché of self adjusting...) until theyre at a point where you can just fit the drum back on...
next step is one you can skip to straight away, wouldnt recommend it tho, lift the handbrake gaitor and you'll see the adjustment nuts and thread.
