1 - 9 of 9 Posts
hi Guys,
I'm newly back to BMW motors after a string of Audi's. My previous Bm was a 91 520i SE. Lovely motor.
Now i have recently purchased a 92 325i coupe off ebay. This too is a nice motor but with some little niggles.....here goes.....
1, N/S window only goes up or down in 'inch' movements at a time. Would replacing the window regulator/mechansim resolve this?
2, The leather door cards have shrunk :frown Is there any way of having the leather re-fitted etc?
3, since yesterday, the rear end ofthe vehicle has a little 'snake' to it. ESPECIALLY on the ICE! I've noticed that the N/S/R tyre is wearing on the inner edge much quicker than the rest of the tyre. Also, a very harsh 'knock' has appeared like the suspension is hitting directly onto the bottom of the arch/bodywork??
4, Engine seems to pull in 'stages' up until about 4.5k then pulls smoothly after this.
I know this is a lot of question from a newbie, but would reallly appreciate any help/advice as i need my car for work and saturday is my only day off to try and resolve some of the issues i have.
Thanks in advance,
Dan
hi Guys,
Thanks in advance,
Dan
1) Could be regulator or window alignment
2) There are various companies that specialise in leather re-trimming
3) More than likely rear trailing arm bushes for snaking, Tyre may well have been fitted to front at some point (Ignore if different sizes) Advise 4 wheel alignment check to include camber castor settings. The Knock could be a bad shock absorber or the commonly known bushes that bush that's attached to the top of the rear shock.
4) Advise Diagnostic scan, could be a sensor on the engine or a coil pack on it's way out.
Hope this helps:thumbsup
Cheers for the info!
Is there any diagnostic software that is available for home use on a laptop? I had Vag-com which did my audi's and was a great piece of kit.
I'm going to reomve the rear wheels tomorrow and check around. All the tyres are the same size on my car.
Dan
Discussion Starter · #7 ·
hello and welcome, sounds like you,ve purchased a bag sh..
sorry only joking, all your car needs is a bit of tlc and some patients.
Thank you.
to be honest, i've never seen a 92 3 series with such fantastic bodywork! :thumbsup
Once everything else is sorted it will be a very tidy car.
Just hope can do it all! lol
Carsoft is available, it's like VAG.com but you need a old lap top to get it working usually from what I hear.
While you are checking your rear end out have a good look at the rear springs, they are known to break.
Also check the window regulator is tight, they sometimes come loose, give the window runners a good lube up and then try the window.
Discussion Starter · #9 ·
cheers, will look out for the carsoft.
THe car has just had full new 30mm lowering springs fitted all round as there was a front spring cracked found during mot. Maybe its not been tightened up properly? Will have a look this afternoon.
Also, will try the window runners and lube it.
THanks for the advice, will post back soon!
Dan
1 - 9 of 9 Posts
