1 - 9 of 9 Posts
is the thermostat in my car 2 pieces?
i.e. the housing and the actual thermostat
my housing is made of metal not plastic so im guessing its 2 parts and can be bought separately
guess what im doing on friday lol
ive been told i can replace it without having to remove all the cowling and fan, is it possible?
It'll be tight but possible.
First time I removed mine is when the engine was out. Go careful though as if you end up snapping a bolt then you may have to remove a whole lot more:silly
Discussion Starter · #7 ·
yeah ive been told they are prone to snapping, ill cake them with some UB40 and see if it helps
cheers again
Discussion Starter · #8 ·
well got it done without removing the fan, it wasnt the easiest but with a couple extension bars i managed it
would have been easier if i had the hands of a borrower and 3 elbows lol
now i have hot air in the car and the temp needle now sits dead in the center and not always on the blue
Discussion Starter · #9 ·
i also changed the oil, filter and new plugs so i ended up lying in a mess of oil water and anti freeze lol was a fun day
1 - 9 of 9 Posts
