hi guys,
this is my first post so i hope its in the correct section, ive been lurking for a while and the sites already helped me through a multitude of problems, i was going to make an intro post but i really dont feel like taking any pics of her when she may be going to the scrapheap :grumpy
the car is a 1991 E36 316 saloon, the mot is due at the end of the month and i have a couple of problems-
1) balljoints are toast - i have two control arms with balljoints etc already in place ready to go on, i went to fit these yesterday and realised the nuts that are holding the old ones on are severely corroded/rusted, i didnt even attempt to put a spanner on them, i did douse them with wd-40 ready for the next attempt, question is, if i cant remove the nuts, will i be able to cut through the balljoint area with a hacksaw? (i also have an angle grinder, but i dont think theres enough room to use it).
2) spongy brakes - i realised after adjusting the handbrake (drum brakes), that my front brakes were spongy, im sure they were'nt like that until i started messing with the rears?, i checked the fluid level and it was very low so i topped it up- still spongy, i decided to manually bleed them and guess what? - the bleed nipples are totally corroded aswell, so i was going to try the scrapyards and see if i can find a decent set of calipers,
so, is there anything im missing before i go for different calipers / could i just replace the nipples?
could air have got into the system because of low fluid or is the master cylinder at fault?
sorry for the long-winded post but i thought id describe the problems as best i can
thanks in advance
thanks in advance
