Right i replaced both the thrust and control arms a few weeks ago...
I am currently investigating a bit of a wandering issue.
I replaced my control arms, thrust arms, tie rods, centre tie rod..
The idler bush is in good condition.
Ive also replaced the rear subframe bushes and pitman arms..
Ive had the car tracked several times now and i still have a wandering issue...
When i accelerate hard it will move gracefully right towards the middle of the road.. But with half throttle it will stay straight... Ive had it tracked at 3 different places to no avail... And when i go over an adverse camber, it will steer into it, left or right...
I went over what ive done time and time again and the only thing ive done wrong is the main thrust and control arm pins, i torqued them up without the load on the suspension, so i tightened them freely, with the suspension at the bottom of its travel... Could this cause an issue like this? :confused
thanks...:thumbsup
thanks...:thumbsup
