well the engine swap went mint apart from killing the gear linkage arm on removal :mad. does anyone know if it has to be a specific e30 325 gear linkage or is there a more common one available from say - an e36? the gearbox is a getrag 260. also if anyone has an e30 325 prop around the midlands - i believe its just the front section that needs changing and not the whole shabang - gimme a holla asap!
cheers :)
Discussion Starter #2
just viewed real oem archive. looks like i need part 25111221201. to boot its not the same part number as one i snapped on the 240 box (must be slightly shorter).
ballsh :frown
