Hi guys, my m50'd e30 has a slight flat spot between sort of 3000rpm and 5000 ish, I've changed the lambda sensor today and idle is tip top now. What could be causing this?
Plugs looked good before I chucked the engine in and replaced a visibly broken coil pack today to.
What else could I check for?? Thought I'd add, when the car is warmed up the flat is more noticable, its not huge but I notice it.
Thanx for any shared info in advance
Ant :cool
Ant :cool
