1 - 20 of 30 Posts
Hello i have a bmw 325e 1987 car starts fine and i drive awhile then car seems to flood out , i pull over and let car sit about 1 or 2 minutes restart car runs fine , i do this very often , could it be bad injector , fuel pump , i installed new hoses ect.. too . i give gas and just floods out , very wierd tbh , in advance thnxz ;)
no lose of power , i pull over and put car in park it idles fine and accelerates fine too does flood.
Discussion Starter · #7 ·
it clogs out putters like , i pull over turn off car , wait 1 min restart car runs fine for a few miles or a day or two some times
Discussion Starter · #9 · (Edited)
hmm tbh i hav'nt gone on a long drive yet , but it run's g8t when it's not doing it , it has power i give gas it fly's , just when i take foot off gas at times it putters like floods out , i go slow and it doesnt fix problen so i pull over .
If when you take your foot off the gas the car tries to cut out then it's got a air leak, If it loses power(go) when driving with foot on the throttle then could be a electrical fault or fuel starvation.
We need you to test it out and post back more info, drive it at speed somewhere safe and see if it does it
BFuk Moderator
next time take note of temp guage, if problem only starts when temp gets ~ half way, it is the blue coolant temp sensor near the thermostat causing your problem
Discussion Starter · #13 ·
Cool guy's i'll drive today and test both u guy's suggestion's and reply asap when i return . Again THANK'S ;)
Discussion Starter · #14 ·
update i drove bimmer for a long ride at 75 miles about 20 miles and return home ok nothing happen car ran fine ..... wierd should i clean my icv and if so with what product is good and i read maybe it be also my fuel pressure regulator maybe bad ?
The idle control valve is always worth cleaning out on a E30 BMW, Throttle body or carb cleaner is good
Discussion Starter · #17 ·
Hello , sorry havnt replied back drove car to a family members house to test at a high speed at on highway at 75 mph ran g8t for a whole day ,nxt day i left to go home was fine until i got halfway home car started gaging again ,i gave it gas and car wounld'nt go anyfaster and like it flooded out ,so i pulled ovr and turn off car and let it set for a few miniutes then restarted car drove fine for about 5 to 7 miles then i repeated steps again , i made it home ;) i clean icv now im going to clean mass flow w/crc masss flow cleaner , this car drive's like a charm when it not acting up , i changed oil and filled car up and put in lucas fuel injector cleanr too im going to look for a fuel pressure regulator too, once again thankz ;)
Discussion Starter · #18 ·
cleaned icv and massflow and car seems to be bettr ,going to give a test drive in a few to see if all is good .... thnkz again ;)
Discussion Starter · #19 ·
same results car doesnt accelorate when i give gas aftr awhile of driving , again i pull ovr and turn off car wait a few minutes and car runs fine , then a few miles down da road car hesatates again ,looks like it does it when car gets warm .. going to do more search , but wont giveup ;)
1 - 20 of 30 Posts
