1 - 1 of 1 Posts
Hello 👋🏻
I’ve had intermittent fault with my passenger side rear light cluster. Kept telling me now and again that my left rear brake light had gone and then all the lights had failed on that cluster. Looked it up and it sounded like a common earth fault which could be fixed by a simple soldering iron (to push the earth pin back though) and a bit of filing.
Finally took the cluster off this aft and the pin is much shorter, but on the reverse it doesn’t seem to have been pushed in at all.
Do you think the pin may have snapped into the connection?
Was hoping this would be really simple (cheap) to fix
269777
269778
269777
1 - 1 of 1 Posts
