18 button obc problem
Tags
18 button obc
2K views 7 replies 4 participants last post by  ct29rip
#1 ·
Hi! I have an e36 325i which was first an 318tds, everything good after swaping the engines but i tried to upgrade my 7 button obc to an 18 buttons obc, I wired everything like the bentley manual.. but the obc doesn't display the fuel consumption and speed, can anyone help me with an idea?
#2 ·
this any help?
#5 ·
No, OBC just not wired correctly, otherwise ABS light on, plus the speedo signal is off the diff casing sensor not the wheel sensors.
If speedo works its not the sensors
Reactions: ct29rip and payno
#6 ·
@payno the ABS it's working
@E36Coupe328 i wired the OBC according to Bentley Manual, the speedo works fine, so I'm guessing there's a problem between the cockpit wiring from the TDS and the engine compartment wiring camed with the new engine
This is how I wired the OBC:
OBC X1071 white plug - pin 1 to pin 15 X1659 EWS plug
4 - 10 turn indicator
5 - 12 X16 white plug dashboard
6 - 21 X16
7 - 11 X16
8 - 18 X1070 black plug OBC
9 - 10 X17 blue plug Dashboard
13 - 17 X1070
OBC X1070 Black Plug already on the car from the 7-buttons obc : 3 - 5 X1074 CCM
4 - 7 X1074 CCM
5 - 3 X1074 CCM
6 - 26 X17
8 - Black/Green wire from ZKE Module
9 - 4 X17
13 - 2 X17
15 - 24 X17
16 - 2 X16
#8 ·
I think i found the problem, according to the ETM wiring diagram there are 2 diference on dash wiring from diesel to petrol, so pin 21 from x16 plug which provides fuel consumption, on diesel DDE plug is pin 49 and on petrol cars is: for M3 and 325i pin 46 on DME, for 316i and 318i is pin 17 DME, for 320,323,328i is pin 9 DME.... And for speed signal pin 2 from X17 plug goes to pin 29 on diesel DDE plug and for petrol cars : M3 pin 42 DME, rest of petrols engines pin 73 DME. Waiting for tomorrow to do changes on DME plug and hope to work!
