1993 325i best way to remove side mouldings
563 views 2 replies 3 participants last post by  dazza316i
#1 ·
hi everyone,
im going to be replacing my side mouldings with m side mouldings this week so want to know my best and easiest way to remove old ones with out causing damage to the car or mouldings??
any advice??
dan.
#2 ·
if you have a snap on pop clip removel tool it is very simple start and the edge then wen one clip is popped out gentle pull trim until you can see the next clip and repeat process until al clips are out.
it is easy with the clip removel tool but can also be done the a flat head screw driver but is trickier as the clip removel tool slides round the clip you can only release one side of the clip at a time with flat head.
hope this helps!
